Peter41
Linux and Windows Operating System Printer Sharing
many solution are proposed in this field and they all can allow you to share the printer between windows and linux OS, some of them include working with SAMBA; but i think the best and the easiest way for sharing printer in local environment fire walled against the outside access is to use the solution provided in this link : and the solution provided under the following is also a SAMBA based solution but won't have to into the hassel of administration to do it, it is quite easy and useful. So follow the steps provided there and you shall quickly get your sharing dream up and running!
Download Link
hope this helps
Thanks!!
