ryans
Posted on - 09/13/2011
hi
i have this error now and i need you to show me the way to succeed and to never have this again because
The Debian installer finds /dev/vda, detects it size but when trying to create partitions,
kernel throws an " I/O error,dev vda,sector0" i need your help friends
Linux debian input output error
This problem can be created for many reasons. You have to login as root user and then try to copy data from one directory to another. If that works you will need to chows the files what you are copying. Select all of them by your username. Then mount on them of your desktop.
Other option is mount your DVD drive again. May be it has some kind of connection problem. Mount up again will recover that problem. And also try to mount vart. It will build some image that can recognize this kind of problem. Vart is a useful tool for it.
Your other option is if you have an internet connection then go to search option of your internet browser and find something useful for you.
