haroldd1
Posted on - 09/12/2011
Definitely debian is not easy to install and this time i have this
Error " no boot loader installed" what is the boot loader and how can i install it ?
Help this is not an easy one. Should I continue the installation by forcing or clicking the ok button? i waiting to hear from you
The error image :
Continue without boot loader
No boot loader installed
No boot loader has been installed, either because you chose not to or because your specific architecture doesn't support a boot loader yet.
You will need to boot manually with the kernel on partition/dev/sda1 and root=/dev/sda1 passed as a kernel argument.Â
Linux debian no boot loader installed
Boot Loader is a small program that loads the operating system of a computer into memory. When a computer is powered-up or restarted. In some windows versions the boot loader are already installed with operating systems. But with Linux sometimes we have to install some special boot loaders.
 In Debian there are some default boot loaders. Â
·        DebianSqueeze
·        DebianLenny
Also these boot loaders are available.
·        GRUB : GRand Unified Bootloader
·        GRUB2 (PC) : GRand Unified Bootloader, "version 2" (PC/BIOS version)
·        GRUB2 (EFI) : GRand Unified Bootloader, "version 2" (EFI version)
·        LILO : LInux LOader – The Classic OS loader can load Linux and others
·        ELILO : Bootloader for systems using EFI-based firmware
So if you want to know how to install the boot loader for Debian, follows this link
https://wiki.debian.org/Grub
Thank you …
