gracya
Posted on - 09/12/2011
Hello brothers and sisters,
It's my first time to be here and i want to highly appreciate because this is a good website. please can someone help me with this error because i use Linux debian and encounter this error while trying to browse wordlist dictionary libraries.
Error:
[ ! ! ] Dictionaries-common: Worldlist dictionary
/cdrom/ : Please insert the disc labeled: 'Debian GNU/Linux testing _Wheezy_ -Official Snapshot amd64 NETINST Binary-1 20110519-01:11' in the drive '/cdrom/' and press enter.
Media change
    <Go back>
Linux debian wordlist dictionary error
Hello Gracya,
Well did you try changing the default word list while running the application? Or do you have a single word list installed? Also did you tried upgrading the debian testing box and I am sure it will work.
Also try uninstalling the word list and then install it again and after that configure it correctly. If possible install the American word list. This will solve your problem.
Good Luck.
Thanks!!
Greetings!
Looks like the system requires something for you to install before it function properly. But it also depends on the source of your word list it can be corrupt that is why you are facing this error, try to uninstall the application and install again. If same problem persists , try looking for another installer of the word list you need.
Regards!
