Linux Distribution Best for Beginners
What kind of Linux distribution will be best for Linux beginners?
I would like to try Linux however, I don't want to mess around with things and I want it to just work after installation.
The best Linux distribution for beginners would be Linux Mint,which is simplified for users coming from Windows because it actually works like windows. It has a very polished software installer where you can download a lot of applications.
It has less things to configure since it has a lot of applications installed already like the flash plugin,video and audio decoders were pre-installed with the base distribution and you can also install free Ubuntu applications on Linux Mint.
Even if you are new, amateur or a professional who has been using Linux systems for a considerable time, you would definitely have a suggestion for the best distribution.
The following five are considered to be best among distribution involving Linux systems..
If you’ve been using Microsoft Windows for a very long time and want to try other operating systems, you may want to try your hand on Zorin OS. It is one of the best Linux distros according to CNET and is a good replacement for Microsoft Windows and OS X. It is designed to improve the performance of your computer, make it more secure, and more powerful.
Zorin OS is based on Linux Ubuntu and built on the same open-source software that powers everything from the International Space Station up to the United States Department of Defense. It is also not a problem using your Windows applications on Zorin OS. You can install them using Wine. It is also pretty much accessible to other languages. The operating system has been translated to more than 50 languages.
Zorin OS comes in two editions: Ultimate and Core. Zorin OS Ultimate costs 19 Euros and features everything Zorin Core has plus more additional features. Zorin OS Core is totally free and is available in 32-bit and 64-bit versions.
Zorin OS requires 1 GHz or faster Single Core processor, 1.5 GB RAM, 10 GB hard drive space for Zorin OS Core and 20 GB for Zorin OS Ultimate, and 800 x 600 screen resolution.
Notifications
