Linux fails to open parse core spland
I had some error messages when I tried to start the application. I don’t know how to fix this error or how to prevent this one to appear in the future. Can anyone help me please to fix this error ? What is causing this one ?
Thank you experts !
Could not parse core.splang. Skipping it.
Answered By 590495 points N/A #180239
I don’t think you will get this error in all of your applications because if you do then there must be something wrong with your system or with your operating system. If you get this from one of your programs then check if it is still working properly or gives random error every time you use it.
Try reinstalling the application or maybe upgrade it to the latest version. You probably want to upgrade it to the latest version instead of just reinstalling it. Visit the official website of the program to check for an available update. If a new version is available then download it. Once downloaded, navigate to the download folder then double-click the installer to install and upgrade your current application.
