Linux open exchange 2010 edb, need help with this one
Hi guys, I need your help.
I have a Linux open exchange 2010 edb file which is corrupted,
Can you teach me ways that can help me recovery this important file.
Thanks
Thanks
Hello Jane,
Don't worry, with the solutions that I offer you, You will successfully recover or restore your file.
At least smile for that, anyway just kidding.
If this fails download FileRec software, install and run and specify the file then click restore.
That should do it.
Good luck!
Hi Jane,
You can visit the following links which will definitely be of help to you.
They provide detailed discussions about recovering the EDB File when it's corrupted.
Hope it helps!
Regards
Hi Jane,
The last one will help you most, as the problem was posted just 6 weeks ago.
Hope it helps!
Regards
