Linux shopt for changing shell properties
What exactly is this shopt command I never heard of it. I wanted to know whether this command is related to changing properties of shell or bash prompt. Please explain clearly.
Dear user,
This is a bulletin Command. Not only shopt but there are many. Such as,
bash, :, ., [, alias, bg, bind, break, builtin, cd, command, compgen, complete, continue, declare, dirs, disown, echo, enable, eval, exec, exit, export, fc, fg, getopts, hash, help, history, jobs, kill, let, local, logout, popd, printf, pushd, pwd, read, readonly, return, set, shift, shopt, source, suspend, test, times, trap, type, typeset, ulimit, umask, unalias, unset, wait – bash built-in commands,
and yes as you said this command is used for changing properties and shell or bash prompt.
you can read more about this shopt command from the below link:
there are some examples given too.
https://www.lifewire.com/uses-of-xargs-command-2201091
Thank you
Shopt is a short term that stands for shell options or SHell OPTions. It is a built-in command in Linux that changes the properties of a shell like its history behavior, spell check, enable special characters for echo command by default, and others. It is a brilliant command that offers more control on shell when you are working on sh shells and bash.
Here are several examples of the shopt command:
