Linux software support required solution for complexity
I have recently installed Linux operating system and now I am having trouble with the software. I need someone to instruct me with the software. The normal software does not seem to work on it. Kindly someone instruct me with the software so that I can easily install the software.
Alec Hughes
Answered By 590495 points N/A #106806
Before installing any software, be sure to check first the product’s system specifications or system requirements before proceeding on the installation. Most users have the habit of just installing a software without knowing first if the application will really work on the computer or not.
There are factors to consider and needs to be checked before deciding to install a product. You need to check if the program is compatible with your operating system. If the application and your operating system don’t match and is not compatible with each other, it will not work even if you continue installing it.
Your operating system’s version should be included on the program’s supported list of platforms. If your operating system is not there, then just find another version that supports your operating system.
You also need to check the program’s required amount of RAM. If you have a very low RAM capacity or your RAM level is below the required amount, the application might perform very poorly. And you should also have a processor that is fast enough for the software.
