Linux vs Windows which is best?
Hello experts!
I need help. I've been planning to buy an Acer Aspire netbook. I checked few offers online but the problem is the OS that they comes with it. They do offer Linux but I am very familiar with Windows. I just want to find out the difference between the two OS and which is better.
Thanks for you help in advance.
Best Answer by Jocelyn679
Answered By 0 points N/A #118807
Windows is good. It is a user friendly operating system. You can do dual booting. If you prefer to use Windows,then you can use it. Then if you want also to use Linux for you to learn what is Linux and to practice Linux.
You can also use it. Some properties of Linux is same also with Windows but you have to give time to familiarized the system. But as of now, you have to use Windows first the  you ask tell the technician that he will make it dual. Windows and Linux
Thank you
Answered By 0 points N/A #118808
Windows is an OS that is user friendly.You can use windows OS without any difficulty even if you don’t know how to use it.You just have to know a little about windows OS.
Linux is also a good OS ,but as compared to windows its difficult.Its not as user friendly as Windows is.You have to spend a long time for learning and handling Linux because it’s totally a new world of OS.
As you are familiar with windows so its better you have windows OS rather than Linux because its difficult to manage as compared to Windows.
That is why Linux is not user friendly OS.
