List of good and simple modern templates
I need a list of good and simple modern templates for a fixed width web design with at least 3 columns.
Hi.
If you want code for template that you are looking for, it will be difficult for you to please someone to do that or to give that to you without something in return, but there are sites that just give and share some templates for free, please try this site if you can find simple templates that you are looking for, those sites is designed in 3 columns.
Good luck.
Hi Archer,
Please look at the following links. The templates are free and easy to use.
This template site is called All-free-download.com and here you will find a wide range of beautiful templates of 3 columns.
This is another website with 3 column templates that range from personal to business.
Here you will find 3 column templates with XHTML, CSS and jQuery form validation.
