Davis Avon
20 points
Posted on - 09/24/2012
Hi guys,
My FTP Archive Directory is showing an error massage.
The screenshot of the error message is attached herewith.
If you have any idea regarding the error message please let me know.
Is it a virus issue?
Error
List index out of bounds (2838)
The error is not a virus issue. Every application has certain minimum and maximum values that it can take. These values are set at the time of programming the application. As the values in your computer have exceeded the maximum value allowed by the application, you have received the out of bounds error message.
To solve this error you have to remove the items on the list. As the list is a long one, you can break it into two halves. Select the first half of the files in the list and perform the operation. After you complete the first half, select the second half and perform the operation.
This should solve your problem.
