List index out of bounds error in ConvertXToDVD
Hi Everyone,
I hope someone can figure out what is wrong with my ConvertX, this problem frustrates me. If I try to remove a chapter settings pin using the delete key, the screen gets filled with a ‘List index out of bounds’ error along with the chapter number(given in brackets) I am trying to remove. And the only way to get out of this is to kill the process using task manager. I am using ConvertexToDVD4 and I have tried uninstalling and reinstalling the software. But the problem persists. Can anyone give me any ideas on how to fix this problem? Thank you for all the suggestions.
List Index out of bounds (9)
Answered By 590495 points N/A #179550
This doesn’t normally happen to converters. Check again if your computer meets all the requirements based on the version you are using. If you are using an old version, you should upgrade to the latest version, ConvertXtoDVD 5. It supports Windows XP, Windows Vista, Windows 7, and Windows 8. I suspect that you are using an old version of ConvertXtoDVD that’s why you encountered this.
This shouldn’t happen on newer version of the converter. It would also help if you will update your operating system to the latest Service Pack since you are using Microsoft Windows XP. To update to the latest Service Pack, visit Windows XP Service Pack 3 Network Installation. This is the standalone or offline version of the installer so you can save the file in your hard drive.
Once the update is finished, restart your computer then try converting again. You should also make sure that you have at least 512 MB RAM available when using ConvertXtoDVD.
