Howdie! I am currently using Samsung Media Composer 6 in editing my audio and video. Now that the features are only limited, I wanted to get a list of Samsung Media Composer 6 plugins so I can choose on the list which to download to enhance my editing experience using this software. I don't have something in particular on what plugin to use so a list will really be helpful. Your help will highly be appreciated guys, thank you in advance!
List of Samsung Media Composer 6 Plugins
Hi John,
I assume you are using AVID media composer software for your Samsung device.
I would suggest following link to download the extra plug-ins that you require in order to have an edge on your current editing experience.
http://www.softwaregeek.com/avid-media-composer-plugins/p1.html
It's worthwhile to note that these options will provide you freeware application catering to your operating system you are running.
Hope this helps.
Thanks
Baker
Hi John,
I believed that you are using Avid Media Composer Video Editor to edit audio and video files. This software offers a unique features, creative functionality and user friendly design. If you want to add some more plug-ins to add some fancy ideas to your work, you can try Blackmagic Design, Boris FX, Digital Film Effects, Film Light and a whole lot more. To review and download all the available plug-ins, kindly click the link below.
Avid Media Composer Plug-ins and Options
Ware
