Listed Com.android.phone Error Fix Methods
I am looking for com.android.phoneerror fix methods but I have not been able to find any fixes. Please help me fix this process stopped error problem. Guys please help me.
![](https://www.techyv.com/sites/default/users/Images-Folder/phone-error-fix-300x199.jpg)
The problems you are facing can be fixed by-
It seems that process is among the processes that make the Android mobile operating system run. If you have a removable battery, try this: turn off your phone then wait for it to completely turn off. After this, open the back cover and remove the battery then wait about 5 to 10 seconds. Next, reinstall the battery and turn on the phone. See if the error comes back.
If this doesn’t work, the best remedy is to factory reset your phone. That’s the only way to restore the system files that run the device. Backup your phone’s data to your computer using your phone’s PC suite if you have any or just try copying your important files and apps to your memory card.
Once your phone is backed up, remove the memory card and go to “Settings” then look for “Factory reset” then just follow the instructions. Before doing the factory reset, make sure your phone is fully charged to avoid any problems.
