The Lists Of Best Six Laptops Ideal For Purchase
Which laptop would be on your list of best six laptops one cannot afford not to have or ignore when buying a laptop? What are the various distinct features of each of these laptops? Why do you term these six laptops per your list as the best? And among these laptops which of these one is relatively affordable compared to functional features and the likes? Thank you.
Answered By 590495 points N/A #189782
If you want to buy a new laptop and you want to have one of the best, check one of these. First up is the Apple MacBook Pro 13-inch with Retina Display (2015). It runs on Apple OS X El Capitan Mac OS X Yosemite powered by Intel Core i5-5257U 2.7 GHz processor and Intel Iris 6100 GPU. It has 8 GB RAM with 128 GB internal hard drive.
It has a widescreen display at 2560 x 1600 native screen resolution with screen size only about 13.3 inches. It supports Wi-Fi 802.11ac (2.4+5.0 GHz dual-band). The standard battery rundown time is about 11 hours 10 minutes. Next on the line is the Apple MacBook Pro 15-inch with Retina Display (2015). It runs on Mac OS X Yosemite powered by Intel Core i7-4770HQ 2.2 GHz processor and Intel Iris Pro 5200 GPU.
It has 16 GB RAM with 256 GB internal hard drive. It has a widescreen display at 2880 x 1800 native screen resolution with screen size only about 15.4 inches. It supports Wi-Fi 802.11ac (2.4+5.0 GHz Dual-band). Standard battery rundown time is about 11 hours 31 minutes.
