Live Mesh won’t run on windows 7 64bits
Asked By 1000 points N/A Posted on -
Hi folks, please allow me to post here my problem in installing Live Mesh, an error message appeared on my screen and inform me with compatibility issue, see below the screen shot I pasted.
Live Mesh
This product can be installed on US English versions of
Windows XP Service Pace 2 (32-bit) and Vista (32-bit and 64-bit)
This problem started when I shifted to Windows 7 64bit.  Earlier  with Windows Vista 32bits there was no problem.  I also saw somebody using Windows Live Mesh on a Windows 7 64bit, that is why I am thinking why, when I installed it on my Windows 7  64bits it won't work.
I can't figure out what I missed, or do I need some other files in order for this to run on Windows 7 64bits.
Please share your thoughts on my issue, thanks.
Best Answer by Sharath Reddy
Answered By 0 points N/A #123262
Which version of Live Mesh do you use? If you are using an old version Live Mesh version 32 bit, it will not run on Windows 7 64 bits.
Live Mesh 32 bits is not compatible with Windows 7 64 bits.
So, what you can do is to uninstall the old version and install a new one Live Mesh version 64 bit.
If you are using the right version, I would advice to try to reinstall your Windows 7 64 bits and it should work after this.
Answered By 590495 points N/A #123263
If you see other users using Live Mesh on a Windows 7 operating system then that version of the application supports Windows 7. The copy of Live Mesh that you got is only intended to be installed on Windows XP 32-bit Service Pack 2,
Windows Vista 32-bit, and Windows Vista 64-bit operating systems. This version of Live Mesh that you have doesn’t support Windows 7. You can fix this problem by acquiring the version of Live Mesh that supports Windows 7 64-bit.
If obtaining another copy of Live Mesh that already supports Windows 7 64-bit needs purchasing it, you can decide whether to buy it or just install back your previous operating system that worked with your current version of Live Mesh.
