Hi all,Â
Is there any antivirus named live premium antivirus that will help to scan and remove virus from our system with the help of internet. One of my friends told that it’s a fake Antivirus Malware. Please advise me to find a real online antivirus that can be premium as well.
Live premium antivirus that will help to scan and remove virus
Well live premium antivirus is not really a name to an antivirus but rather it is a category of antivirus that are active. Actually antivirus over the internet are mainly of two types, the Demo versions and the Premium Active antivirus.
Now the Demo or Trial antivirus last just a few days after installation and does not offer much security to your Computer while the Premium antivirus last for much longer days, months and even years and offer maximum protection to your computer.
Now all you have to do is search over the internet for an antivirus of your choice (Avast, Avira, Norton just to name a few) and chose the premium download which will require payments, after that you can then install it and your computer is secured from malware and antivirus.
Hello Sophia,Â
I think I would advise you to use kasperskey Internet Security, the current version of 2013 and make sure it's a genuine stuff. For details about it, visit: https://usa.kaspersky.com/. It works on all commonly used windows like Windows 7, Windows 8, XP and it will treat your computers from all the threats you have heard about.
Thank you.
