Live traffic feed for website
Hi Friends,
I am using WordPress and would like to know about how to add live traffic feed for website. Please do the needful for guiding me for doing the same, so that I can display the information regarding number of visitors along with their country name.
Thanks,
Arthur W Adams
Answered By 0 points N/A #128857
IP Marker provides just the tool you need.
It shows the accurate Geo-location of your visitors as well as how many of them they are.
1 Head over to IP Marker and click on free widget.
2 Follow the directions given > Then click on generate code and copy it.
3 Go to your blogs dashboard > Add widget > Paste the code you copied and click save.
4 Drag the widget to the desired position you want to display live traffic on your site.
Feedjit ALSO provides a widget that shows live traffic on your site.
1 Go to Feedjit Free Live Traffic Feed and register for a free account.
2 After registration > Click on Get Your Traffic Feed > Install Feedjit On My Blog
3 Copy the widget code
4 Go to your WordPress dashboard > Click on widgets
5 Click edit on the widget of your choice and paste the code your obtained from feedjit and click save.
6 Drag the widget to the position (on your sidebar) where you want to display the traffic feed statistics.
