LLBGen Pro v2.0 is being installed
Hi I want install LLBGen Pro v2.0 software on my computer. I tried many times for install this software but I failed.
I see an error message when I install it.
"The installer has encountered an unexpected error installing this package.This may indicate a problem with package.
The error code is 2869".
How can I fix this error message?
I need help immediately. Please help me.
Thank you
Answered By 590495 points N/A #125094
That dialog box is informing you that the setup suspects that there is a problem with its own installation files.
It means that even if you try installing it again and again, it will still stop at this point because of the error.
Maybe one or two of the files needed for the installation is corrupted and can not be loaded or read.
If you downloaded this LLBLGen Pro v2.0 installer from a site in the internet, you got a broken installer.
Try searching other sites for the same installer.
If you bought its installer CD, ask for a replacement.
You got a defective one.
