LMS error message for online traffic school
I am trying to take online traffic school and keep getting error lms not able to download the online traffic syllabus.
To resolve that issue, you will need to do the following:
Nicke
I think this is a problem with your connection and not with the site since the Online Traffic School is accessed via the web browser. Try checking your internet connection first. Visit other websites to see if you can load some pages. Or simply visit a video sharing site like YouTube to see how fast a video can buffer.
Select any video and then play it in your web browser. The video will buffer up fast if you have a good connection. If ever you have a bad connection, try doing it again during off-peak hours to make sure you have a good connection. You may also check the network cable attached at the back of your CPU.
Make sure the cable is attached properly. If you are subscribed on a cabled DSL internet, contact your network provider about your connection problem. But if you are using a wireless broadband internet on a 3G / 4G USB dongle stick then this could be a signal problem. Check with the modem’s dashboard if your location receives good signal.
If it doesn’t, simply transfer to a different location that has a good signal reception.
