jack001
Posted on - 08/27/2011
Hey,
I am using 512 Kbps Internet connection in my PC. I want to share it equally for Browsing and Download. Just like, If I download a file, it will be take 256 Kbps from 512 Kbps and if I browse from any browser it will be take 256 Kbps from 512 Kbps.
Is there any way to do this job?
Thank You…
Load Balancing with one Internet Connection!!!!!
This kind of problem is a bit difficult to fix. First, you paid only for 512 kbps. In order to see your download and upload speed. Just go to this LINK speedtest. This site will give you the maximum speed that you can upload and download.
If you want to have a good speed connection, you must upgrade you internet to 1 MBPS up.
With this you can actually monitor your download and upload to its maximum speed of: EXAMPLE BELOW
This is an upgraded Internet connection of 1 Mbps.
If you want a faster connection then, I highly recommend to upgrade it. 1 Mbps to 5 Mbps.
