Load MP3 Music Files in Winamp Music Player
Hi guys,
How to use an mp3 player? My current operating system is windows xp and using winamp as a music player which is compatible with my os. I would like to ask if how can I load the mp3 files in the playlist as well as how to play a specific song.
Expecting some help, thank you.
Answered By 0 points N/A #165922
Hello! If you have created your playlist go to FILE then select OPEN PLAYLIST or simply ctrl + O. If not, you should go to FILE the select PLAY FILE (or simply L) then find and select the MP3 files you want to be played then OK. If you want a specific song or songs to be played you should create a PLAYLIST. Go to FILE select PLAY FILE or  PLAY FOLDER(if it is organized and saved in just one folder) then OK. Go to FILE the select SAVE PLAYLIST or simply ctrl + s. Hope this will help you. Thank You and God Bless.
