Loading time of the website
Asked By 260 points N/A Posted on -
Hello ,
I like the Techyv very much because I find every type of  computer problem solution here.
So it's good all the functionalities are good no need for the improvement.
But the website is bit heavy that’s why it takes time to open.
So if the opening speed of the website is better its good.
Best Answer by superuser
Answered By 4875 points N/A #121565
Thanks for the message
Yes we had issues previously and now we have upgraded to a Dedicated server and higher Ram that before.
We do have plan to move the website to the Cloud where we will have no issues on speed ever.
Smart solution of increase and decrease the hardware resource as per the traffic each day.
Answered By 0 points N/A #196018
Good day,
Make sure you update your browser,or check the internet connection
There might be a problem with it,or try to get closer the WiFi Cable.
Jacksonn Maria
