Local area connection icon has disappeared?
Help please my local area connection icon disappeared I need it to see if my DSL works or unplugged and I can’t check it any time what can I do can anyone tell me how to restore it
Your problem is very simple
 Follow my steps please
I hope my solution is satisfying
Regards Â
Pitler rothÂ
The connection has limited or no connectivity. You might not be able to access the internet or some network resources. For more information click the message. Upon clicking on the message the window comes up that states, local area connection status. You might not be able to access the internet or some network resources. This problem occurred because the network did not assign a network address to the computer. To restart the connection and try to establish fill connectivity, click Repair. If clicking repair does not restore connectivity, the problem might be with network, not with your computer. Contact the person who manages your network. Clicking repair brings up this message; windows could not finish repairing the problem because the following action cannot be completed. Renewing your IP address, call for assistant, contact the person who manages your work. Restarting the computer brings the connection back. It is possible that during the process of removing viruses and spyware that a setting was changed by accident.
Hello Dear,
It is very easy to get back your local area network connection icon in system tray.
First right click on "my network places" icon and choose properties. A window will open, in this window your all internet or local area network connections will be available.
Simply right click on that network icon and choose again properties.Â
This window will appear,
Just check in "Show icon in notification are when connected" and then click on OK button.
Icon will be placed in system tray.
Thanks
