Local Failures were detected. No action is required
Hi People,
Can someone please help me with my mail problem? I’ve just downloaded Zimbra with Outlook connector. I’m having synchronization issues and I can’t send and receive mails. Seems that I’m getting “This object does not have an ID, it is a newly created item”.
Please help.
Thank you for the help.
– – – – – – – ERROR 1 — – – – – – – – – – –
Local Failures were detected. No action is required.
This e-mail was generated for technical support purposes.
Sync Type: Delta Sync
Store: Zimbra – FirstNameLastName
Computer Name: PC1
ZCO Version: 7.1.3.6347
Server Version: 7.1.3_GA_3346
Error Code: -2147221240
Error Message: Unknown error 0x80040108
– – – – – – – ERROR 2 — – – – – – – – – – –
Computer Name: PC2
Error Code: -2147221233
Error Message: Unknown error 0x8004010F
