Local Policy Editor Windows 7 For Editing.
Editors are necessary to keep our document error free. One of the built-in tool is local policy editor. How to use local policy editor Windows 7?
You can open the local policy editor in Windows 7, 8, Server 2008 R2 and Server 2012. Ways to open it
1) Using command prompt.
2) Using Microsoft Management Console.
• COMMAND PROMPT
ï‚§ Open the start menu.
ï‚§ Enter gpedit.msc in the search field.
ï‚§ You will be redirected to the policy editor.
• MMC
If you wish to save the editor console and to select the GPO that will open from the Command prompt then click on ‘Allow the focus of Group Policy Snap-in to be changed when launching from the command line’ from the ‘Select Group Policy Object’ window.
