Locating the entry point libintl_snprintf while running the GIMP
My problem is that I could not locate the entry point libintl_snprintf while I tried to run GIMP, in my dynamic link library. I also tried to use plug-ins, just to open the entry point, but still, couldn't avail. Can you please help in fixing my problem?  C
Answered By 20 points N/A #111942
Hi friend,
You could not locate the entry point libintl_snprintf because it is not there while you running GIMP. There is a file named intl.dll. This file holds windows broken application. When that error shows at the time of running GIMP the windows detect GIMP application as a broken application and locked it into intl.dll.
In order to solve this problem you need to take out GIMP from intl.dll folder or rename intl.dll folder so windows could not find that folder. The folder location is WindowsSystem32 directory. Go there and rename intl.dll folder. Then your GIMP will be running perfectly.
