karengsam
10 points
Posted on - 03/22/2013
Hello, I got a problem about lock internet access for some sites. So I can’t visit some website directly. But when I type the website name in Google then I can access to websites. Please help me to resolve this problem and give me the answer. Thanks.
Lock internet access for some websites
Hello Karengsam,
Its really a bad experience and the problem appears to be complex but you just have to get it done with a few steps as outlined below;
1. Download the latest Mozilla Firefox set up from this link http://www.mozilla.org/en-US/Firefox/new/ possibly your browser could be faulty
2. install it on your machine
After all these steps just start using your problem will be solved
Thank you
Hi Karengsam,
Uninstalling and Reinstalling is a great idea but that would be your last resort. This kind of occurrences happens when you have an AVG Safe Search Enabled from the add-ons in your browser. Check steps below on how to disable.
IE:
Go to Tools.
Select Manage Add-ons
Click Enable or Disable add-ons
FireFox:
Go to Tools
Select Add-ons
Look for “Extensions” tab.
Look for AVG Safe Search.
Click Disable.
Hope this helps. Keep us posted!
