Lockdown requirements in force may be conflicting
This error incurs if you happen to remove or reinstall the Citrix Receiver that cause some incorrect setting in your Registry. To resolve this issue, you need to open your Registry window and add an entry in the specified path:
For 32-Bit System:
HKLMSOFTWAREWow6432NodeCitrixICA ClientEngineLockdown ProfilesAll RegionsLockdownVirtual ChannelsControl
For 64-Bit System:
Note: Be sure to back up your registry before editing it. To launch your Registry window, click Start>Run and then type regedit and press enter or OK.
And then, add the string to the ClientHostedApps and change its value to FALSE as shown on the screenshot below:
Click OK and then close your Registry window and try to access the Citrix environment again.
