Locks records in access database
How can you lock records in MS Access database once you update it? And how will you set up the user interface to include only the form you would like for the user to complete?
Thanks,
Renato
Answered By 0 points N/A #99380
Yes, you can lock record in the Access database using some VBA code in a form’s OnCurrent event. You can make a field in the table called “ISLOCKED”. After that in the OnCurrent event code is:
IF ISLOCKED THEN
       FORM1.ALOOWEDITS =TRUE
ELSE
       FORM1.ALLOWEDITS = FALSE
END IF
You may also want to set ALLOWDELETIONS too.
If you want to allow the users to see only some textboxes of the form, you need to make then visible or invisible.
IF ISLOCKED THEN
       FORM.TEXTBOX1.VISIBLE = TRUE
ELSE
       FORM1.TEXTBOX1.VISIBLE = FALSE
END IF
Let me know if you have any other questions or comments.
