lussy lussy
Posted on - 02/02/2013
I have been playing Modern Warfare and my computer heats up and goes off at particular sections. In case I use a different route, this doesn't happen. Which software do you recommend that can allow me to log GPU CPU and view their utilization/performance when playing?
Thank you.
Log gpu cpu when playing a game
Hello Lussy,
Good day!
It's good that you have posted your concern on this site.If you want to determine the statistics of yourÂ
GPU and CPU while playing Call of Duty Modern Warfare, you can use "Lavalys Everest" software.This software will
show realtime reports of your GPUand CPU.This software will be useful for you regarding with your problem.
Good luck!
Rois Louise
Hello Lussy,
Playing high end games like Modern Warfare will definitely heat up your CPU and GPU. First make sure you have minimum specification to run the game. Have good power supply and cooler for your PC. Now in terms of software to monitor your GPU and CPU logs, the best one I would recommend to you is HW Monitor. It is a program that reads PC systems like voltages, fan's speed, temperature. It can also read modern CPUs on-die core thermal sensor. All the latest chipset from Nvidia, ATI, and Intel are supported. Here is the download link.
Hope it helps! Have a nice day.
Wagner Desantiago
