Good day,
I badly need help concerning an error code. Whenever I attempt to login, I receive this “Log notification: fatal” in which I have no idea what it means. I am to my wits end because it tells me that I might want to save my logfiles! Anyone is welcome to give their thoughts on this.
Thank you very much.
“Never_Get_Here violation”
Where
Identifier=ClassificationInligucia
Log notification: fatal error while login
Hi Jeanne L Jackson,
I had the same problem a few months ago. You should try to go on your browser and delete all your history and all your cache memory. Than restart your computer and upgrade your browser. After that you should check your system with an Antivirus program.This should help you fix your problem.
Hi Jeanne,
Regarding with that error message, try logging in on another browser aside from the one that you are used where you got that error so that you could isolate the issue if it is a browser problem. If it still persists, clear all the cookies and history from your web browser.
