At least 50 to 70 software installed in my computer. Generally it does not create any problem while using them. Now I installed a new software and the system asked me to reboot. After rebooting I can not access to the main desktop page. The circle is just spinning. How can I access to the desktop now.
Log in problem in Windows 7
Hey Tanya Garcia!
The reason behind the slow speed of your computer is might be your damaged and broken registry. You can download registry fixer from the internet.
First of all try to run your windows in Safe Mode. Then uninstall the last software which you have installed. After that you will be able to log in the windows.
I would like to recommend you to download Tune-up Utilities. This software is very easy to use that optimize the speed of your computer. It will automatically fix the damaged or broken registry and also defrag your drive which needs to be defragged. Also this software will give you tips that how you can optimize your system speed. Just download it from the internet.
Hope it will help you in optimizing your system speed.
Thanks
Tunacao caroon.
