Hello fellows,
The log transport application has stopped working. What will happen to my computer operating system if this log transport application will not be able to work anymore? I have to be aware of these things that may harm my computer system, I am currently using windows XP OS. I hope you share with me your ideas.
Isabella Barry.
Hi Isabella,
A Log Transportation Application (LogTransport2.exe) is developed by Adobe Incorporated. This program/application is not a harmful executable file. You are free to disable it permanently. The common path of this file is in the subfolder in program files which has 2 mb-3 mb size. You can delete it if you want or disable it permanently without a loss in your computer Operating System.
Adobe Systems Incorporation is the one who develops LogTransport2.exe. It is found in the Program Files sub-folder at the size of about 2-3 KB. No worries regarding the infection detection, it’s safe. You can safely disable it by clicking Help>>Improvement Program Options then select >> No.
