Logfile error while testing a clone
I am facing a problem in testing a clone on an error free drive. I tested it and an error code appeared on the screen Code:
If this is the first time it happened on your application, try deleting the clone, restart your computer then try it again. See if it’ll work again. If it still doesn’t work, try uninstalling the program that you are using in cloning then restart your system when asked. After booting, check your computer for any possible errors.
Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, or Norton SystemWorks. Install the application again after this and see if you can clone again.
If it’s still the same, I think you need to restore your USB flash drive and remove it from being a bootable flash drive.
Notifications
