I’m using Logic Pro 9 to edit, mix, and record music on my Macbook. This Logic Pro 9 application runs on Rosetta 800 interface. I forward the tracks to a rack gear for more tracking after mixing and compressing the music using external analog EQs. The Logic Pro 9 is having a problem. This involves signal delays of 5 to 25 milliseconds. Even when the low latency monitoring is on, the Logic Pro signal delay still occurs. However, the performance of the Logic Pro 9 is better. Any idea on how the problem can be remedied? Thanks for helping.
Logic Pro 9 is having signal delays
The signal delays in the logic pro may be caused by the settings that you have configured it to use. You may want to access the tools and check the delay time that you have set and other settings like the frequencies and try to adjust them and see if you will get the right transmission rate for the signals. You may also want to consider the time when that problem started to happen. If the application was working well before and it started having problems lately, then it could be corrupt and the remedy for that will be to perform a clean installation to fix the bugs it has.
-Experttechyv
