greggory1
Posted on - 09/13/2011
Hi there
Iam using a http server with Linux debian os but i have some login problems at the main site but in the other places like home i can log without problem what can cause this ?
The error is " The message says: runtime error, "
amannan
Login problem with a http server on debian
Hay greggory
You have server problems with linux debian. You can recover it by changing your main homepage. Must be ignored your last browsing homepage..
check out the first homepage will able to run or offline. If it is offline changed there. This may one for you.
server IP or home connection will not recognize there you may change somehow. Go Network and home connection make the connection linked up network.
Before checking you can try seeing local or business connection which you did select at first from connection. I mean local connection will be band or alive check out. this option you get from Network>>Connection>>local connection.
These three option will make your linux available.
