Login Problem Occurred Displays an Error
Currently I am using Party poker. An error message appears to me out of the blue that says:                “You just logged in from a different computer. You current session will be terminated. In case       you have received this message in error, please contact the Customer Support immediately.” As    I continue to login the same error persist to appear? Do I need to logout from my PC at home to be able to use this application? Is there any other way to fix this?
partyPoker.com
Answered By 0 points N/A #174465
Hi Sue K Burgos,
For security purposes and anti infiltration system, the game party poker.com included an error about intersecting logins from multiple PCs, obviously, when two PCs collide for one single account, the server might be confused on which data will be accepted and which data will be rejected, to fix this, please assure yourself that you have logged out your account on your home first before connecting to another device.
