The Logitech K760 Solar Keyboard
How to charge the Logitech K760 solar keyboard? Once I charge it how long will it go? What is its price?
I want to know more about the Logitech K760 solar keyboard.
Logitech K760 solar keyboard is operated completely through an ambient light. This is a wireless keyboard made exclusively for Mac OS, iPad and iPhones. If the device is fully charged, it gives the user an ample power up to three months at 8-hours per day.
The K750 is similar to the K750 with one general distinction. It's composed of keen numeric keypad and a full-size arrow and function keys and a lot more with a preferably compact design. It also has a hardware switch on and off.
It can work with 3 devices at the same time. Just simply press the F1, F2 and F3 keys to instantly select which among the three devices is connected to the keyboard dynamically.
Other functions that you can get from its function keys are Brightness, Play and Pause buttons, Volume and the Eject key to control a device.
You can avail it on its retail price of $80.
Hello Calvin,
You are asking about how to charge Logitech K760 solar keyboard. Well, for the fact that it is a solar keyboard, it means that it has a solar charger which there are no accessible batteries at all. The solar panel charges for any kind of light even office light so you don't need to charge it at all. The battery life will last long three months straight complete darkness. It is a Bluetooth device that will get paired with multiple device in a snap. It works well because it pairs easily and works perfectly. It is very comfortable to type it is composed of apple chiclet keys. Its price is just $80.00.
I hope the information I have given will help you.
