dittehobbs
Posted on - 09/18/2011
First I am using Monitor. But due to eye effect I replace it with LCD.
But today my LCD is not working proper when I try to open any media player or any game then I receive below error and some time LCD don’t display any thing also some time white spot appear on my LCD.
I am very confused about it what is this please tell me any one about this error.
Logitech LCD Manager
Logitech LCD Manager has encountered a problem and needs to close.
We are sorry for the inconvenience.
If you were in the middle of something, the information you were working on might be lost.
If you noticed some white spots that appear in your LCD display, maybe you are beginning to have a problem with your video card. Try cleaning first your video card. Shutdown your computer, unplug it in the AC outlet and then open your CPU case.
Remove the video card from the slot. Just use an ordinary pencil eraser when cleaning the video card. Rub it on the copper end of the card, do it on both sides then wipe it off with a clean cloth to remove the rubber particles. Attach it again on the slot and turn on your computer. Uninstall Logitech LCD Manager and then run a disk check on drive C.
Right click on drive C and then choose Properties.
Click Tools tab.
Click Check Now button.
Check Automatically fix file system errors and then click Start.
After the disk check install Logitech LCD Manager again. Try opening again those programs that previously caused error.
If the error is still there, you need to replace your video card. Your LCD monitor only displays what the video card relays.
