Logitech Pro 9000 update installation error
A Logitech Pro 9000 webcam and Windows XP SP3 is what I have. It displays an error message and quits when I try to download and install the latest webcam software. Attached is the error message.
Logitech Webcam Software Installation
We were able to install the software. This could be due to any of the following issues:
– Not enough disk space. Be sure you have enough disk space on your computer to install this software.
– There is already another install in progress,Be sure that you are not trying to install other software at the same time.
– You don't have permission to install software on this computer. Log in as an administrator or check with your computer's administrator.
– Your installation media is is damaged. There may be some missing files. You can downlad the latest software from the website and try the install again.
– You can also restart your computer and attempt the software installation again.
OK
