I am planning to buy a new protective case for my iPad Air 2. I am bit confused on choosing the right case for my device. One of my friend said that the Logitech’s case function as a horizontal stand that can hold your new iPad at any angle. My query is it worth buying this Logitech’s product for my iPad. Kindly suggest me with your ideas.
Logitech’s AnyAngle case holds your new iPad at any angle, tried it?
Logitech is quality accessory maker for both iPhones, And iPads, You won't go wrong buying a Logitech case, This particular case is one of its kind, It has this unique kickstand, The kickstand is adjustable at any angle, So yes it does hold your ipad at any angle, It is also no exception of logitech other cases, It is a high quality case, Which makes your iPad looks more beatiful than It already looks, I say you shoild go for it.
