Hi there,
LogMeIn gives me this error sometimes and at the most of the times it appears when I work a long time. I have reinstalled the program, upgraded, updated my drivers and nothing seems to work. Can anyone help me please to fix this error ? What is causing this ?
Thanks !
LogMeIn Control Panel
LogMeIn Control Panel has encountered a problem and needs to close. We are sorry for the inconvenience.
If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem.
We have created an error report that you can send to us. We will treat this report as confidential and anonymous.
To see what data this error report contains, click here.
Debog
Send Error Report
Don’t Send
If you are using a non-server operating system, I don’t think this is a compatibility issue because LogMeIn Hamachi supports Windows XP, Windows Vista, Windows 7, and Windows 8 unless you are using a lot older operating system. For servers, it supports Windows Server 2003 Standard, Windows Small Business Server 2003, Windows Server 2008 Standard, and Windows Small Business Server 2008.
For Mac OS X, it supports Mac OS X 10.5 Leopard, 10.6 Snow Leopard, 10.7 Lion, and 10.8 Mountain Lion. Mac OS X 10.9 Mavericks is not supported. If you are using Windows 2000 or earlier, you need to replace your operating system to any of the supported operating systems. There is no specific requirement for memory which means it consumes very less memory so RAM is not an issue.
It is also possible that you have a very small memory installed on your computer and you open too many applications at the same time together with LogMeIn Hamachi. If this is the case, installing more RAM might fix the problem. If this is not an option, try using LogMeIn Hamachi without running other programs.
