LogMeIn Plugin 1 does not support the security for Safari
Hi there,
Recently I have experienced this kind of message. I didn’t allow for the permission because I was afraid that will harm my PC. Should I allow this ? Why it appears every time and is really necessary to give these permissions ?
Thank you !
“LogMeIn Plugin 1.0.0935” does not support the highest level of security for Safari plug-ins.
Websites using this plug-in may be able to access your personal documents and data.
When visiting other websites: Allow Always
Answered By 590495 points N/A #176605
I know you want the best security for your Mac computer because unlike before where MAC OS X operating systems are not being targeted by viruses, nowadays coders are also trying to infect this operating system. That’s why there are antivirus software that supports Mac OS X because of these threats on the security of the computer.
Since I think you are using the LogMeIn Plug-in as a plug-in for your Safari web browser, it seems like the security level you are implementing or in effect in your web browser is very high for the plug-in to work properly. I think the level of security is already preventing the plug-in from working. Consider changing the security level until the plug-in works properly.
You will know that the plug-in is already comfortable with the security level when you no longer see that message.
