Hmaim
30 points
Posted on - 07/19/2011
I am working on a development of private company’s software. I have installed much software’s which are required for that software. The issue is this that I have no UPS and any other device and here I am facing load shading problem. Sometimes load shading makes my computer system’s window corrupt and I need to reinstall my OS also other software’s again. Is there any solution that can fix this issue without UPS or any other expense involvement?
Fahar
10 points
Long Time Windows OS security
I think you need to backup your system and every time when this issue will occur. Restore backup and start working.
Another solution is this, every time you face this problem, just upgrade your Windows OS don't install fresh copy. In case of up-gradation you don't need to install all other software's except Windows Operating System. Try it.
Fizra
20 points
Taking Backup and restoring also takes much time. Is there any other time saving solution for this to fix up?
Fahar
10 points
Another very simple and time saving solution for this problem is a software.
Deep Freeze Software is used to freeze your drive or complete computer but in this case you need to freeze only your OS having Drive like C drive mostly. Install the software and when it asks you to freeze the drive you required select your Operating System's Drive. It will freeze the drive permanently and whenever you will restart your system, it will be in the same position as you freeze it without any change.
In case of virus attack, you just need to restart your system and windows will be started from the point you save/Freeze it.
Download DeepFreeze software with latest version from any saved website and install and Enjoy.
Hmaim
30 points
Gorgeous, it’s superb; I can’t imagine that there can be a solution for this with reinstallation. Thanks a lot Fahar. Thanks a lot.
But one more thing please, what will be condition when i need to install or make changes in OS drive? Whenever i will restart it will be still on the frozen position or not?
Fahar
10 points
This is a very supportive software for this kind of issues. When you will install the software, after installation you need to restart windows. After restarting, software will ask you for password. You need to enter a unique password and save this. After that whenever you will need to make changes in your OS drive press Alt+Ctrl+Shift+F6.
Deep freeze window will appear, type your password, new window will appear, click on "Boot Thawed" and clock ok then restart your system.
Keep in mind that whenever you are making change to your deep freeze software, you need to restart it first then do other work. After making desired changes, don't forget to select "Boot Frozen" option from the Deep Freeze software menu, and again restart to freeze drive on this situation. Enjoy this valuable software.
Hmaim
30 points
Thanks a lot Fahar for your valuable solutions.
