I know phones are getting expensive as years go by but I need to buy one. I’m not into latest models since they become obsolete very fast. I also want to know what’s the inside or the specifications so I would know what I’m buying. Looking for Oppo Smartphones, any 2018 model will do. I wish you can include the specifications in detail.
There are many 2018 versions of the Oppo Smartphone and one is the Oppo A3s. The Oppo A3s is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public and released on July 2018 measuring 156.2 x 75.6 x 8.2 millimeters and weighing 168 grams. It is a dual SIM Smartphone and uses nano-SIM card.
Oppo A3s
It has IPS LCD capacitive touchscreen display with 16M colors at 720 x 1520 pixels screen resolution and protected with Corning Gorilla Glass 3. It runs or ships with either Android 8.1 Oreo or ColorOS 5.1 powered by 14 nm Qualcomm SDM450 Snapdragon 450 chipset, 1.8 GHz Octa-Core Cortex-A53 processor, and Adreno 506 GPU. It supports microSD expandable up to 256 GB.
It runs on 2 GB RAM with 16 GB internal storage. The primary camera is a dual camera featuring LED flash, panorama, and HDR and supports 1080p video recording at 30 fps: first camera supports 13 megapixels with f/2.2 and AF; second camera supports 2 megapixels with f/2.4 and depth sensor. The secondary camera supports 8 megapixels with f/2.2.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with WiFi Direct and hotspot support, Bluetooth 4.2 with A2DP and LE support, GPS with A-GPS support, FM radio, and microUSB 2.0 with USB On-The-Go support. It has built-in accelerometer, proximity, and compass sensors. It runs on non-removable 5V/4A 20W: (VOOC Flash Charge) fast charging Li-Ion 4230 mAh battery.
1....
