Looking for 230 240 nokia
HI,
I am using Nokia phone with 230*240 resolution. Please suggest me some java software and wallpaper websites for my 230 240 Nokia phone.
Thanks! Â
Best Regards.
HI,
Thanks! Â
Best Regards.
Hi Dixon,
Here are some sites that compatible to your Nokia Phone with 230×240 resolutions. You can search there your favorite wallpapers, java games, screensavers, themes, videos, and ringtones. I recommend you to these sites and it’s free to download. Hope it would be helpful and you will enjoy the free application.
Hi Dixon,
There are several mobile websites you can visit to download games, applications and wallpapers that’s compatible with your Nokia phone. Here are some trusted sites you can use. I use these sites to download applications on my Nokia phone. You just have to set or choose your device on the site so it will give you the list of compatible apps and wallpapers.
Hope this helps you.
