Looking for Acer 5920g graphics card upgrade
I currently have an Acer Aspire 5920g laptop with Intel Core 2 Duo 2.66 GHz processor, 500 GB HDD, Windows OS Vista 64 bit and 256 MB NVIDIA GeForce 8600M.
I plan on upgrading my Acer 5920g graphics card so I can play and view HD content.
Can someone here suggest a high-end video card that is compatible with my laptop?
Answered By 240 points N/A #184217
Hi Christian,
I believe I will be able to help you solve this query in the best way possible, the high-end video card compatibility.
With your laptop computer can be found from the website;
Asus Video Card
I believe this is one of the best cards especially if you are into gaming, it is one of the fastest cards from NVIDIA manufacturers and it has a 3 month warranty.
You can either buy it online or locally from your nearest computer shop. Remove your previous card from the computer when it is unplugged from the socket and replace it with the new card, and it should work better and quicker.
This should solve your query.
