I'm looking for an Acer battery utility software that will provide me with all the battery data including the discharge cycle count. I have an Acer Aspire S7 with Intel Core i7 3.0 GHz, 4 GB DDR3 RAM and Windows 8 OS. Any suggestions?
Looking for Acer battery utility software
Hello Stephens,
That is a very good laptop configuration you have got.
You can get the latest efficient Battery Widgets. Here is Battery Utilities
CNet.com is a software download site which is best in the market and weekly updates with the best products made by developers all over the world.
Generally I would advise you to go for products with a high editors' rating first and then consider the User rating among them.
Hence in the link given above currently I would advise you to try Battery Meter and Battery Care.
Hello!
For your Acer you could use the features given by Windows 8, which include battery status and economy mode for when your are not connected to an electric source. If you would like even more information on you battery status, you could use the Smarter Battery Software, which is specially created for Windows 8 and that gives you all kind of data regarding your battery.
Smarter Battery download
Good luck!
